- Aug 14, 2014
So wife has a thing for square monitors, went to Amazon to pick out a cheap one, OCD spoke louder and ended up with this one. Hooked it up to her 660Ti with a VGA-DVI adapter and seemed to be working fine (very slight ghosting). Problems start in Windows, it shows ALL resolutions and frequencies up to 4K/170hz with the non-UPNP default driver, tried switching to a "flat screen 1280x1024 75hz" and the fairly outdated Vista driver form the manufacturer, no change. Using Nvidia 361.91 drivers if it helps. Is there any way to cut out all resolutions/frequencies except the ones she actually needs for Windows/games ?
Tried Doom today and it shows "input out of range error" when it starts but seems to work well enough on other games.
http://au.agneovo.com/au/content/f-417.asp
FX-4300, 4.7ghz 1.316v
Hyper 212 EVO - SP120 LED 120mm x2
Asus M5A97 EVO R2.0
MSI GeForce GTX 660 Ti - N660Ti PE 2GD5/OC
2x4gb Corsair Vengeance LP - 9-9-9-24 1600mhz
Crucial M4-CT064M4SSD2 64gb
WD10EZEX 7200rpm 1TB
Corsair TX750
NZXT S340 - AF140-LED x3 - AF120-LED x1
AG Neovo F417 17"
Windows 10 TH2 Pro 64bit
Asus M5A97 EVO R2.0
Corsair TX750
AG Neovo F417 17"
