- Nov 12, 2002
- Rootstown, OH
- Thread Starter
- #41
I like no uncertain terms. So we're basically talking about what sort of layout we want in the base, and what sort of depth/mass we should center there.
Really, I'd wager a guess that it doesn't matter too much. A big hunk of copper sitting on top of the CPU with LN2 being poured into it is going to work pretty well regardless. Would like to get a better feel for the ranges of thickness between the base and the bottom of the drilled out holes, as well as how long the holes are from top to bottom.
Looking around at the party, I'd guess that its maybe an inch or inch and a half from the base to the top of where the holes were drilled? And I'd guess it looked like the holes went nearly all the way down to the base, save a quarter of an inch maybe where the probe was drilled. I think there is more specific information out there regarding how to drill a hole in the base, and how much room there is to drill into there for the probe placement without risking putting hole right to the inside of the pot. I haven't looked around enough to find anything like that, but I'd guess it has probably been found.
