10XTriplet
Disabled
- Aug 20, 2012
Is there a way to lock down Windows 7 Pro to be only allowed to run a few programs?
If so, how?
If so, how?
While hafa posted some great links, I think that may be more than you're looking to do. If that's the case, I submit my reply for your perusal.
7 Pro has a GREAT...GREAT tool for security policies.
Press Windows+R (run)
Type "secpol.msc" to open the Local Security Policy snap-in.
From here, you can control the effective permissions system wide.
Now, to simply block some software except what you want them to run, do the following.
Open secpol.msc
Right click on "Software Restriction Policies"
Click "New Software Restriction Policies"
(optional) In the right hand pane, double-click the "Enforcement" object. From here, you can specify who the policy applies to. (I would make it apply to non-admin users... just in case)
Double click the Additional Rules
Right click and pick the application rule you want to add (more below on differences)
Give them either basic user (recommended) or unrestricted (if you want them to have admin rights when running) access to each program.
Now, go to Security Levels and make the "Disallowed" the default policy.
No programs will run except what you specifically defined.
Now, regarding the application rules, you have four options:
Certificate: Just what it sounds like. Don't use this option.
Hash: This is the best option. It will take a snapshot of the .exe hash and allow only that specific program to run. Name/Location do not matter.
Network Zone: I've not used this and have a minimal understanding. This is for web-based applications/installs. As long as your hash rules are set, there is no need to worry about this.
Path: This works on basic users. If you list c:\ solitaire.exe as a blocked application, I can simply rename it to c:\the.exe and run it. Hash prevents this workaround.
When you right-click Software Restriction Policies, you don't have the New Software Restrictions Policy option available from the context menu?
You don't see that option because they already exist
(By default, 7 Pro will not create them, hence my step above)
Skip to the next part of the walkthrough above.
