Have you tested the fan with power straight from the PSU? It could very well be that your 200CFM fan overloaded the CPU Fan header and IT shut the fan off to protect itself... I've never heard of a fan blowing up because you connected it to a fan header; it's usually the other way around.
And no the fans not broken, plug it into the psu. I guarantee it starts up
Right. Thats for the PCI express lanes, not for mobo fan headers. Something seems peculiar about this whole thing...He is talking about the 4 pin Auxiliary PCI Express graphics power connector his board has. http://downloadmirror.intel.com/15640/eng/DX48BT2_ProductGuide01_English.pdf
Remember when you first started learning about building computers and for a short while you knew just enough to be dangerous?
From the technical specs of Loki's motherboard:
Table 25. Fan Header Current Capability
Fan Header Maximum Available Current
Processor fan 2.0 A
Front chassis fan 1.5 A
MCH Fan 3.5 A (direct connect 12V rail)
Rear chassis fan 1.5 A
Auxiliary rear chassis fan 2.0 A
Loki - There is one fan header that might can handle your fan but your fan will be stressing it. It is the 3 pin fan header right next to the corner of your CPU. I suspect it was the one you first used.
You might want to read the owner's manual that I linked above and the tech spec manual located here: http://downloadmirror.intel.com/15640/eng/DX48BT2_TechProdSpec.pdf
I did put it back the way it was. And yes, fans do run backwards when you flip the polarity.
some CAN run backwards, most do not (there's a thread around here somewhere about that). I think you need to call and cancel that RMA, because you killed the fan on your own, it was no fault of the manufacturer.
Oh well, your karma, not mine.
PC fan blades usually have a curved design, so even if the rewiring would have worked, the airflow in reverse wouldn't have been as good as airflow in the direction the blades were designed for. It would have been so much easier to just turn the fan around...
Yep, I think this just about sums up this thread:
Dude, you blew up your fan. If the retailer knows what you did and is still replacing it, that's on them. We've all done stupid stuff like that but make no mistake, it's not the fan's fault this happened.
Mod note time: This thread could easily take a (somewhat justifiable) turn for the worse after this little revelation. I would strongly encourage future posters to not allow it to happen.
You never have no choice You just have to think outside the box sometimes, you could have used something simple as zipties/rubberbands or something more difficult like making a custom mount/shroud to hold the fan in place.
I've personally attached CPU heatsinks and waterblocks to GPUs using zipties and shoestrings
