- Dec 19, 2012
Hi all My current setup is as follows
I reversed the flow to accomodate the rad in the HD bays. The rad currently has the stock fans pushing, the case fans aren't attached to the rad they just exhaust. I also added a 120 on the side door for the GPU cause it was running hot. I assume because of the reversed air flow.
I am going to install a second GTX 580 DCU II which are 3 bay cards and work very well( even OC'd mine runs in the low 70's), but I feel that my current set up won't provide enough cool air for them.
So I'd like to change things around like so
I'd also like to add two more fans to the rad for a push/pull set up. It reall doesn't work as well as I would think it should in my current setup.
So I have a few questions.
1. would this provide adequate airflow in the case. Or am I creating a vaccuum? Cause I'll have 4 in if you include the side dooor, and 4 out all 120's but there's still the 2 cards and PSU and those cards move quite a bit of air.
2. should I keep the stock fans on the rad and add two or replace them as well. So there'll be 4 identical .
3. should I leave the 200mm fan in the top or will it cause interference with the airflow from the rad.
Would also like suggestions on fans for the rad. Prefferably something available at Tigerdirect.ca or Canadacomputers.com. I have checked some of the fan recommendations in other posts but can't seem to locate them at either one of these outlets.
Thanks
Thanks
