Looking for a free Codec so i can play MP4 in XP media player.
looking fo a safe download.
Or you could go with the simple solution and get VLC Media player (Free, Open Source and super light).
That is exactly what I was going to suggest. With VLC, I've never had to install a codec pack.Thanks went with VLC media player works great.
No one claimed it did. He was merely commenting that VLC didn't.of course CCCP has no downloader, viruses, adware, bloatware, or toolbars.
Or they could simply not include it in the installers.
People could try not hitting next, next, next, next......
of course CCCP has no downloader, viruses, adware, bloatware, or toolbars. VLC? Ugh... Definitely not even close to my favorite program though.
I used to use it till i came across the CCCP, then i discovered just how poor it was for what i needed (you know... play video smoothly... tends to stutter a bit), and how WMP-Classic was so much better. Figure that, an ancient discontinued and free media player armed with all the newest codex is better then the newest thing on the market... It still is as far as i can tell.
What about the ones that deliberately make it difficult to unselect what "extras" they install or flat out do it anyway?
Now that i've had more time to play with VLC and use more functions I have noticed that DVD movies stalls some times for a split second and the picture quality is not as good as cyberlink powerdvd.
This is not even my computer i'm working on, however I like to do good work, so you got me thinking, plus i would just like to see for my self if CCCP is better picture in MP4 and DVD also if it will fix the slight stalls sometimes with DVD.
I was wondering form what you are saying is the codec WMP-Classic better than CCCP codec also does WMP-classic have ads, bloatware, adware, also where can you down load WMP-Classic without a download manger?
stuttering, as far as i can tell happens more often in VLC the higher the resolution of the video is. It seems completely unrelated to computer specs which is why i moved on from it.
WMP-Classic is "Windows Media Player - Classic" the media player that came with windows 95/98 prior to the current windows media player version that popped up in later editions. CCCP is just a codex pack, but one nice thing about it, is it comes with this archaic media player bundled in it (it's so old it's just an exe file, it doesn't even need to install into your system to run).
I've found for movie watching there is no better media player out there.
no better media player out there, are you talking about WMP classic or archaic?
heh... wmp-classic is an archaic (aka old) media player. WMP-Classic is, imho the best media player you can use.
LOL how do you use WMP-Classic in windows XP?
