Here are some test numbers a review site did of this LAPTOPS PERFORMANCE!
Is the P25X V2 any good as a gaming laptop?
Benchmark Score Summary
Time to Desktop 8.77 Seconds
Super Pi @ 1M 9.61 seconds
3D Mark - Ice Storm 1.2 125975
3D Mark - Cloud Gate 1.1 19197
3D Mark - Fire Strike 5605
3D Mark - Sky Diver 16969
Passmark Performance Test 8.0 4948
Cinebench 11.5 Open GL 65.43FPS - CPU 7.38pts
Unigine Heaven 4.0 1296
Unigine Valley 1.0 1443
PC Mark 8 - Home Conventional 3.0 3267
PC Mark 8 - Storage Test 4972
Our standard set of tests as shown in the table below are each run at least 3 times, with the average score taken. The tests were all carried out with the laptop in high performance mode, mains power plugged in and the screen set to 1920 x 1080 resolution. With this laptop we are using the latest Nvidia 340.52 graphics drivers. With the tests it's always worth bearing in mind the relative power of the graphics unit compared to the desktop equivalent and whilst no 800 series desktop GPUs have been released yet according to Passmark's Video Card benchmark, the GTX880M is roughly in the same area as an Nvidia GTX 760Ti which is very impressive for mobile graphics. The GTX880M is currently the fastest mobile GPU available still using the older Kepler chip, but with 1536 pipelines running at 954MHz and with a memory speed of 125MHz.
Since the P25X uses the powerful GTX880M with its huge 8GB of GDDR5 VRAM and a speedy Haswell Quad Core i7-4810MQ CPU you'd expect a lot for your money and we definitely got it here. With Battlefield 4 we received an excellent average 64.14FPS using Ultra settings and 97.86 when lowered to high. Max Payne 3 again gave the system a tough test with 35.62FPS seen with everything pushed to the maximum and a very impressive 65.34 with the settings lowered to high. Compare that to just 23 and 45FPS seen with the P35W v2 with the GTX870M graphics and you can see the increases thanks to the GTX880M graphics.
Gaming Performance 1920 x 1080 Resolution FPS (Fraps)
Battlefield 4 Ultra Settings 64
Battlefield 4 High Settings 98
Sims 4 Medium Settings 31
Max Payne 3 Maximum Settings 30
Max Payne 3 High Settings 65
The benchmark tests again showed the power of the system with decent increases across the board. Highlights being 3267 with PC Mark 8 Home Conventional, 1443 in Unigine Valley 1.0 and having fixed the issue with Passmark Performance Test 8 not using the Nvidia graphics we managed to squeeze out 4969 here. It's worth mentioning that with the Nvidia Optimus technology used in this system it is always best to double check that for gaming the Nvidia GPU is being used as opposed to the onboard Intel HD 4600 graphics.
All this was taken from a review on a web site, so i can not claim how accurate these readings are so i would say just use them as a rough guide, and below is the full review to see. I will be trying some test of my own later on when i can CUSTOMIZE my laptop to the way i want it to be.
1,
https://www.avforums.com/review/gigabyte-p25x-v2-gaming-laptop-review.10680
Happy Reading,
Ajay.
