- Jul 9, 2013
- Sadly Iran :(
I need a Lightweight laptop for my university (Electronics engineering, It's very unlikely but I also might get accepted in another other university and study computer science!).
My budget is 1000$~
My requirements are:
1. Battery life
2. Weight (I'm a wuss and I thought the 13" macbook was heavy c: but I guess I can get used to it! so anything around the same weight is fine)
3. Screen quality! (IPS 1080p+ 13"+)
4. Lasting a long time so I don't have to pay 1000$ again in 2 years or so D:
5. Linux compatibility
6. Any i5+ seems fine to me. I'll be running a few IDEs.
My current choice is HP Spectre x360. but After googling I found out HP isn't very good and that the Spectre x360 has WiFi - Trackpad - Touchscreen issues and some people complained about their display flickering. my brother's 8 year old HP's display started flickering after 2 years so... I'm not really sure if it's a good choice. although the same model just with the i7 didn't have any issues (my old laptop which is as thick as a coin and weights 2.5kg without a battery) also I heard it heats a lot
The other choice was one of asus UX series (they're very similiar. the ux 330 430 305 and most of them seem fine to me. one of them had a WQHD display which seems scary to me considering the price and the fact that some people say those have Fake wqhd displays that look worse than 1080p) but the Displays use PWM for brightness and apparently give you a headache. also the hinge appears to get damaged quickly.
The dell XPS 15-13 other than ghosting are perfect for me. sadly I couldn't find them here ;(
Lenovo X1 carbon is realllly expensive but it's kinda perfect! Googling shows that it has issues too.
Lenovo yoga has a loud fan
Macbook pr 13" costs a bit too much and I can only afford the 128gb version. but considering I have a pretty good and powerful PC at home maybe I can live with that!
Do you have any Suggestions? am I being nitpicky? are the issues with the HP laptops just a few minority?
Thanks <3 ^_^
My budget is 1000$~
1. Battery life
Thanks <3 ^_^
