- Sep 15, 2007
- Small town Emlenton, PA
Wow! You for sure don't need the pumping power, it will make not one iota diff on temps.
We always recommend the same pump for pumpage long term life, think about a very weak pump feeding a strong pump, cavitation like the 35,000 HP for 'nucklar' plants pumps etc. In WC, as long as they are close, it's fine. We are a bitttt less than those pumps......
We overthink sometimes.
Long term, second rig. If you like watercooling buy two. Otherwise, it isn't needed. Your flowrates 1 pump VS two isn't gonna make 1c of difference for GPU's. And that's with the temp measuring tolerance.
Yes, you parellel the PWM signal to the second pump, any more and the mobo circuitry might rebel (lot's of EE math about that, wayyy beyond me)..
Lastly, GPU's aren't particular with temps. Not like CPU's.
One pumpage please for normal usage.
