- May 17, 2012
Good day Gentlemen!
I currently have an EVO Hyper 212 with the stock push fan. Is there a better Air heat sink say with push/pull and at what RPM should I be looking for? Or should I just replace the stock fan on the 212 and get a push/pull for it? I am trying to stay away from water for now. I don't put much stress on my CPU but I would like for it to run cooler. I get about 40C-50C right at the regular operating level with 24/7 OC. Thanks!
Edit: What do you guys think of this one? It looks too big to fit my Asrock but it has 8 heat pipes and 2 fans.
http://www.frozencpu.com/products/1...156_1366_2011_AM2_AM3_FM1.html?tl=g40c14s1037
Edit#2: Copper and Aluminum fins and pipes? Which combo? Does it matter. I would like to get something that matches my rig. with blue LED fans.
Edit#3 Maybe I should just get a push/pull with these.
http://www.frozencpu.com/products/1...-_Blue_BFF-BLF-P12025B-RP.html?tl=g36c365s936
