I built my first AMD PC (and first PC ever) last year.. but one thing that constantly bugs me is the noise in the stock fan. honestly you would think i over work it or something, but it's quite loud while i'm on google chrome.
I don't OC (nor do i plan to), i just want a quieter system while i'm doing basic things... (and have it loud\cool when i really need it)
Right now i have on Cool And Quiet, having it clock to 1.7Ghz under minimal load, up to the full 3.3ghz spec.
With a few windows up and that configuration i'm around 37-38 degrees, and just as a quick test running the OverDrive benchmark i went up to 45 degrees...
Anyway, heres my setup:
3.3Ghz AMD Phenom II x6 1100T BE
ATI Radeon 5750
2x4GB DDR3 RAM (by patriot)
2x 320GB Barricudas (SATA)
1x DVD-RW Drive (SATA)
MSI 880G-E45 Mobo
ThermalTake v3 Case w/
1x120mm fan
considering that OC'ed computers normally need a lot of cooling i came to ask, what do you think i should try first to fix the problem?
BIOS Settings, Invest another case fan? or even a New CPU Fan?
Thanks in advance!
ATI Radeon 5750
MSI 880G-E45 Mobo
1x120mm fan
Thanks in advance!
