- Mar 7, 2008
I know I wont be the first but I'm wondering, how much would dumping a ton of ice into a water cooling loop really help with OC and benching? My thinking is, instead of near ambient coolant temperatures, as long as there is solid ice in the res (assuming adequate mixing) the water will also be near enough to 0C. The question then is, how long would how much ice last?
Assumption: freezers in the UK for long term food storage are typically rated at -18C, so I'll take that as the effective ice temperature. To raise that to 0C would take about 10Wh/kg. Once at 0C to convert ice to water would take a further 92Wh/kg. This isn't bad... let's round it and say you get 100Wh/kg, at a 300W load you could get 20 minutes before 1kg of ice is gone. If you use a large bucket as makeshift reservoir, you could put several kg of ice in there and get over an hour and not have to worry about it.
The other question remains, how much benefit would this give? Essentially it would give around 25C advantage over ambient (depending on weather and if you run aircon). I was debating a WC loop for one system and this could be attempted before I fix it in place. Kinda hoping condensation isn't going to be a problem in the short term if I invert the mobo so any drips will not fall on it.
