- Aug 2, 2012
I am looking at potentially getting the Cooler Master HAF XB Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119265
It says with the top fan installed it supports a cooler that is 155mm tall. I'm guessing something probably in the 140mm tall range would be best, for a little clearance. I also use all 4 memory slots on my UD3, so that is a consideration. I'm also planning on eventually getting an 8320 or the next generation of AMD 6- or 8-core, whenever those finally come out.
What are some of the best low-profile air coolers out there for AM3+? Anything under 155mm works.
