I agree. If me, I would go for something like this. Or for just a little more, there are models with separate antennas you can place high up a wall on desktop for even greater range and flexibility - like this one.Why not a simple PCIe NIC instead?
Ummm, according to the specs for that M.2 card, it uses NGFF. And according to the description (and 3rd image) for that antenna, it states in all UPPER CASE,EarthDog said:This one is in the high end mobos that support Wi-Fi 6 - https://www.newegg.com/p/0XM-004T-00...6662-_-Product
Heck of deal...
And the antenna - https://www.newegg.com/p/2VT-006A-00...0021-_-Product
And that makes sense. How would you route those antenna cables out the back?ONLY USE FOR MINI PCI-E INTERFACE,DO NOT USE FOR NGFF INTERFACE
Ummm, according to the specs for that M.2 card, it uses NGFF. And according to the description (and 3rd image) for that antenna, it states in all UPPER CASE, And that makes sense. How would you route those antenna cables out the back?
I guess I was not clear.1. M.2 is NGFF AFAIK.
Yes! Where are the wire's connectors going to exit the case? If the card is inside and the antennas are outside, the wires have to connect to the antennas somewhere. And what's going to support the antennas on the outside of the case? Sure you can remove a slot cover to run the wires through, but then there would be a gaping hole in the back and the antennas would just have to dangle out the backand the antennas go on outside of that (wires would be on the inside). Did I miss something?
I guess I wasn't clear enough...nothing goes outside of the case except the actual antenna...Yes! Where are the wire's connectors going to exit the case? If the card is inside and the antennas are outside, the wires have to connect to the antennas somewhere. And what's going to support the antennas on the outside of the case? Sure you can remove a slot cover to run the wires through, but then there would be a gaping hole in the back and the antennas would just have to dangle out the back
The first thing I did before replying in this thread, lol!Now that I looked at the rear I/O panel of his motherboard
What makes you say that? They lay flat... the trick is having wires long enough to route under the GPU and up to those ports in the rear IO. Some boards have the M.2 Wifi slot directly behind the ports. If you were talking count, there are two other M.2 slots (one above and one below) for storage. So that assertion is correct, but only if he had two other M.2 drives...That said, I will say if the OP wants to add a M.2 SSD in the future, a M.2 wifi card may be in the way.
Because the M.2 slot will be in use. And so if the other slots are used too, then the wifi card "may" be in the way.Why would you say that? They lay flat...
Please read the edited/entire post... I edited/added a few things for more clarity (the meat of which was there before your reply, LOL).Because the M.2 slot will be in use. And so if the other slots are used too, then the wifi card "may" be in the way.
... that said, the Wi-Fi port doesn't support a storage drive (key-e vs key-m) in the first place.
