I have noticed that the larger heatsink for the chipset in the middle of the motherboard that is held on by spring brackets seems to be loose. it doesnt move by its self but if you press on it, it can rock back and forth. if you leave it for a bit it becomes slightly stuck again but with a bit of pressure it will unstick and rock back and forth. is this normal? is it the thermal paste that is getting un-stuck and thus allowing it to rock back and forth? I havent installed my M4A87TD motherboard or used my motherbaord yet - it is still in its box so im assuming the thermal paste hasnt heated up yet so maybe after it heats up and spreads the heatsink will be more secure?
any ideas?
Thanks
any ideas?
Thanks
