- Thread Starter
- #21
It's actually relatively easy, If you have a jigsaw just cut a hole in the motherboard tray. Then you can do either of the following. Mount a fan using double sided tape to the Cpu backplate or you can then cut a hole in the panel door and mount a fan there. I did the latter and have a 120 mm fan exhausting air out of the case. This is what Johan did to his system.
Wow amazing!. Thank you, you saved me I hope this would lower a bit my socket temps. I mean even 4 Cº would be appreciated!
