- Jun 28, 2012
No windows snipping tool in Win8?
Still here on 8.1?
Don't use salt, it will tear up your rad
Not sure I understand the capacity that you are using DICE ?
Are you just throwing it in a bucket, or do you have a pot ?
if in a bucket what are you activating it with ?
Acetone would not be very good for a rad either ....
On another note, CPU should be max here, 3D clocks are secondary,
use the 13.11 beta or the 13.12 and 5 lod
good luck and welcome to the team Madd
Are you referring to the 12.14 Omega drivers, that are known to be handy capped in OpenCL????
Not sure any knowledge I have is helpful ....
As far as how many posts you have ? i have no idea where that would be ?
I would not worry about it , you will have enough posts sooner or later , not a big deal
the driver you have is better for Vantage, thought we were talking about 03
Edit:
Yes you would be better off with plain ice water
If you go DICE grab a pot and do it up right
It will be included in the next Windows release. So that you have to pay more money for a program that should have been/or was in Windows.No windows snipping tool in Win8?
I think I can shed some light on this. Mandrake(I believe) had mentioned using dice on his rads. Difference is he runs antifreeze in his lines. This is what Johan and I do as well when hanging or rads out of the window in the winter. (Free ice water).
I have experimented with salt water and I was able to get to around -20c before it froze. That was with about 20% salt ratio (very hight). I never actually ran salt water through my lines as it was suggested to me to try antifreeze. I've had that down to about -15c but wasn't able to go colder as it was a mild winter here in michigan.
Anyhow, the short story MM is you should look into running a 50/50 mix of glycol and water if you're looking make a hybrid water loop with DICE.
Good luck.
We need two more categorizes: Gpu: any GPU no more than 4 cards
Hint, hint Johan45
Quad is the max for sli/CFx.Which categorizes??? I have 5 R9 280X's attached to a UD7 that I fold with. 1 Sapphire Dual X, Sapphire Toxic OC, HIS iceQ2 Boost, and 2 ASUS DCII TOP editions.
doesn't your board have pcie dip switches to just disable some? Why not do that?See page 1, Cpu: any GPU no more than 2 cards
