Scared? This is OVERCLOCKERS! LMAO
P.S. I hope that's not your daily driver. If so I wouldn't push tooo hard. Might require new O/S install.
He means that if you push too hard or tweak too much you'll eventually Bork the OS or sometimes the Motherboard BIOS. Most of us that really push our OC's do not do it on our everyday setups or at least have a separate Hd drive/SSD with an OS on it for benching only.what do you mean by , you hope that's not my daily driver?
Agreed!Weirdly low score. It should be higher on 3770K. GTX470 is almost the same card and I was making 400k+ when I had 3770K. Mine was 5.5GHz+ but 5GHz is not that far to score 160k, it's not AMD. Check system, drivers etc as something is clearly wrong.
Yooo's gots to give that cpu some voltage love XrogerXok heres a little update XRogerX/ GTX 560 TI/ AIR/ X1 / 217775
Probably not too much since I'm pretty sure he's running the stock HS, judging by his other thread.Yooo's gots to give that cpu some voltage love XrogerX
Yeah I just noticed that.Probably not too much since I'm pretty sure he's running the stock HS, judging by his other thread.
