Reefa_Madness said:I was unsure from your post whether or not you were so I was trying to get a clarification.
What do you mean by the LEs are better, speed wise? I believe that it depends on your "sweet spot" as to which will produce the better results. If you are wanting to run much over 300 then the LAs are probably a better bet as the LEs may not get as far. If you are wanting to run 275-280, then the LEs will run that at better timings. Of course, if you believe all of the Mushkin Reds press, they will run 275 at 2-2-2 timings, which of course is much better than any TCCD.
Kinda funny if you think about it. Winbond BH5 (the King) is replaced on top by new Samsung TCCD (all hail the new King), which is subsequently dethroned by no other than new Winbond BH/CH (the latest King). The new boss...same as the old boss.
Well there may be some oddball factors that let the lower rated chips run at higher speeds. But thats kind of far fetched don't you think? I mean does any evidence support this? LA's and LE's are both the same chip. LA's are the chips that either cannot run the 3-3 timings, or are used to fill a marketing demand. Logic would say a the better performing chips (LE's) will also perform better at the looser timings also. I don't believe the little transistors in the chips are so dynamic that they would regress in this way because when it comes down to it, the purity and structure integrity is what impacts the perfomance. I don't think 4-4 timings favor dirty silicon.
