i upgraded my memory from 1GB to 2GB (exact same type of memory). everytime during the windows startup screen (when the mouse cursor starts to show), the computer reboots itself automatically. i was able to get into windows one time as it did not reboot itself, and I checked the memory and it says I had 2GB, so I know that i installed the ram correctly. any suggestions?
my system specs are:
amd64 fx-53
1gb (2x512mb) corsair pc3200xl memory, I added 2 more sticks of the EXACT same type memory
2 x 74gb raptors in raid 0
msi k8n neo2 platinum
i have currently 3 partitions and the pagefile is set like this:
C: (windows-smallpartition) - no pagefile
D: (games/programs-largepartition) - initial size of 1536 and max size of 3064
E: (random-smallpartition) no pagefile
here is the link to the motherboard manual which shows how to install memory modules:
http://www.msicomputer.com/product/p_spec.asp?model=K8N_Neo2-F
im not quite sure what it means and what I have to do. my two initial ram sticks are silver colored and are the exact same type and speed as the new ones I bought for upgrading, which are black in color.
The two memory modules were initially in slots 1 and 2 I believe, and I added the 2 new modules to slots 3 and 4.
amd64 fx-53
