pavloschristo
- May 22, 2013
Hi. I'm looking to upgrade the memory in my system
My Current system is:
Intel Core i7 930 @ 2.80 GHz
Asus Rampage II GENE Motherboard
AMD ATI Radeon HD 5770 XXX (875 MHz, 1028 MB @ 1300 Mhz)
OCZ 3x2GB DDR3 Triple Channel @ 534 MHz (sorry I can't be more precise)
OCZ Mod X Stream-Pro 600W PSU
Coolmaster CPU watercooling block (forgotton the model)
Intel 330 120 GB SSD
Windows 7 Home Premium 64-Bit
If I buy another set, say the 'Corsair XMS3 6GB (3x2GB) DDR3 PC3-12800C9 1600MHz Triple Channel (CMX6GX3M3A1600C9)' can I use it along side my current memory or should I replace it instead? Will there difference in speed effect each other?
Thanks
Thanks
