- May 11, 2003
i've been using memtest to see how much more i can raise my system FSB lately. i know you are supposed to set the multiplier to the lowest and then test the memory, but why is that? when you finally raise your multiplier and set your final clock speed, should that be the settings you use for memtest?
i'm asking this cause at 6*235 i'm ok, but at 10*235 memtest fails almost instantaneously.... thanks
