- Dec 13, 2005
The odor isn't a fragrance, it's just the isopropyl alcohol.
Oil makes zero sense. At all.
Like I said, I may have misunderstood. I'm just saying I thought someone mentioned they added something to it besides water
Ive heard that for nail polish remover... that is why we generally say not to use it because of all the additives. By isopropyl alchohol, AFAIK, its just the alc and water or if there is any traces of oil, its VERY VERY little...Thanks, good to know.
I thought someone around here mentioned they'll sometimes add a fragrance to it (don't know why) or some oils to it since some people will use it to clean wounds. But maybe I misunderstood.
Isopropyl alcohol dissolves a wide range of non-polar compounds. It also evaporates quickly, leaves nearly zero oil traces, compared to ethanol, and is relatively non-toxic, compared to alternative solvents. Thus, it is used widely as a solvent and as a cleaning fluid, especially for dissolving oils. Together with ethanol, n-butanol, and methanol, it belongs to the group of alcohol solvents, about 6.4 million tonnes of which utilized worldwide in 2011.[10]
