- Nov 26, 2005
- Concord, NC
Why did you get the 8000 or 8500? It seems from my reading here that 6400 will OC to 8000 or 8500 speeds. Do they have more headroom, or tighter timings? If so, how much better?
jason4207 said:OK...was worried I jumped too fast on the 6400 Ballistix deal. Feelin' good about it now!
These are the right one's to get, right?
corsair doesnt use d9 in their 6400s at all anymore,just promos and elpida i believe.only in the 8000+ will you find d9gmh.Brolloks said:Vendors such as Tigerdirect do not list the rev #, I presume one would then have to buy the RAM, open it up and look at the label to see the revision??
||Console|| said:Yea I have the 6400's they will do 500mhz @ 4-4-4-12 no problem
to everyone getting the crucial ballistix ddr2 800 for $69.99 AR from newegg, if you get D9GMH chips, they should do 3-3-3-8 ddr2 800 or 4-4-4-10/12 ddr2 1000 easily. with enough extra voltage, they might be able to reach 5-5-5-15 ddr2 1200
