- Nov 22, 2001
- The great USA!
Deadbot1_1973 said:This is something they have been forced to by the consortiums behind HDDVD and BluRay. The only time this should be a major gripe to anyone is if they plan on using the system as a media center, in which case hopefully you will be using an HDCP compatible TV and a decent HDCP video card. YOU DO NOT HAVE TO BUY ANY SPECIAL HARDWARE JUST TO RUN THE OS. This only applies to DRM'ed sources as well. If you have a non DRM'ed source then it will play just fine.
MS being "forced" to do this, that is a good one.
And I assume a lot of people will be using it for media centers, considering blu-ray and hd-dvd are already here and we do have a media center version of Windows XP Media Edition.
Nothing like buying a new format dvd like blu-ray or hd-dvd then being told you can only play it at the old dvd format. What's the purpose of having future technology if you CAN"T USE IT the way it was intended?
For example...
It's like buying a new car from the dealer, then the dealer says wait, you can only drive this at 30mph, although the speed limit is 55.
