Just wanted to let anyone looking for a PII DDR2 mobo that I got this and it runs great. In system in sig. Just got started oc'ing but so far it's running like a pro, zero problems setting up and doing a mild oc (stock cooler cleaned & arctic silver 5 applied).
There aren't many formal reviews of the board. It is a 790GX/SB750 setup, one of the best of the boards using this combo IMO. It has extra copper in the pcb, and uses name brand japanese capacitors. I have had caps blow on mobo's and vid cards (and kill other hardware due to leakage) so I appreciate this. Also, very nice heatpiped northbridge and mosfet cooling, and a WIDE range of OC settings and voltages to set.
Note that this mobo is new, just came out in Dec'08/Jan'09. There is a new bios as of 3 days ago (get it, it fixes the bug where your DDR2 is set to single channel and the option to change it in the bios disappears), but the important part is the stock bios works with any PII out right now. So you don't need to stick an older AM2 chip in first and flash like you do with many 790* boards you can get.
On a side note, under load, holy **** the stock fan is loud @full speed! And an unlocked multiplier brings back old memories of a paint unlocked tbird =)
I got this in a combo deal at newegg with the 940BE, -$50 off the total for the win. I have 2 more 2gb sticks of this ram, but it probably won't run @1066 with all 4 slots filled. I will give it a try soon though and report back. For the time being I am still giggly over the massive increase in speed from my old 2.2ghz x2 brisbane @ 2gb of ddr2-800
