where it all boils down to is this:
IF fan A is the more powerfull/faster "push" fan
AND
IF fan B is the weaker/slower "pull" fan
THEN
as long as max speed of fan B is more as the half of max speed of fan A, then you're ok
Assuming they both have more or less the same curves, where the only major difference is the max speed.
Otherwise the fan wiht the higher static pressure has to do the pushing.
thus:
fan A MAX RPM 2000 & fan B MAX RPM 1200 = OK
fan A MAX RPM 2000 & fan B MAX RPM 800 = NOT OK
keeping them closer together is better of course... if the difference is big enough fan B might turn into a dynamo.. probably not good for the fan or the fanheader/circuit of the MB
There are of course A LOT more things at play; for example:
What if fan A is a 25mm thick 3--blade with low SP while fan B a 38mm 7-blade?
What if fans are closely matched, but fan A turns clockwise, while fan B turns anticlockwise (a papst & a delta
), etc, etc , etc
You can get submerged & overwhelmed on the subject for days, weeks, months on end
Also consider this baby, it are actually TWO fans:
https://db.sanyodenki.co.jp/product_db_e/coolingfan/dcfan/dc_fan_detail.php?master_id=2606
bolt THAT one to a radiator
or this one
https://db.sanyodenki.co.jp/product_db_e/coolingfan/dcfan/dc_fan_detail.php?master_id=3113
bolt it to your case, and its the only case fan you'll ever need
