C Caen Registered Joined May 11, 2008 May 16, 2008 #1 Anyone use this instead of the aluminum ones? How well do they match up? Thanks
Perseus Member Joined Dec 12, 2004 Location Hanover Park, IL May 17, 2008 #3 They work fine. I havent had any problem with them yet.
OP C Caen Registered Joined May 11, 2008 May 19, 2008 Thread Starter #4 Thanks Perseus. I ordered my U2-UFO today. Ouch, it hurt to push that submit button.
lokitexas Member Joined Oct 15, 2006 Location Texas May 19, 2008 #5 Caen said: Thanks Perseus. I ordered my U2-UFO today. Ouch, it hurt to push that submit button. Click to expand... Did you get the Hyper Modular? So you customize the case later?
Perseus Member Joined Dec 12, 2004 Location Hanover Park, IL May 19, 2008 #6 Caen said: Thanks Perseus. I ordered my U2-UFO today. Ouch, it hurt to push that submit button. Click to expand... Anytime, Caen. Yup, I was sweating on my mouse just a bit too. You'll be pleased with the purchase, though.
OP C Caen Registered Joined May 11, 2008 May 21, 2008 Thread Starter #7 lokitexas said: Did you get the Hyper Modular? So you customize the case later? Click to expand... I bought this one right here: http://www.mountainmods.com/u2ufo-mirror-black-powder-coat-original-top-p-77.html
lokitexas Member Joined Oct 15, 2006 Location Texas May 21, 2008 #9 Ya yall both lucky. Mine is going on 2 years old...while its the same case, my front and back panels cant be interchanged. The new modular is so cool. I R jealous now.
Perseus Member Joined Dec 12, 2004 Location Hanover Park, IL May 21, 2008 #10 The front and back panels on your case aren't attached by screws to the bottom plate, loki?
