Hey folks.
I have a question about heat pipes. I know that retail CPU cooler heat pipes work by evaporative cooling. The heat of vaporization transfers the heat of the processor to the water molecules, which break away from the liquid and carry the heat as a vapor. When the cool off in the top part of the heatsink, they condense back to liquid and are pulled back to the heat source via the capillary action of a wick. Heat pipes are passive of course. And they are able to achieve cooling from 60-70 degrees C using water.
I understand that part. My question is theoretical. I want to gather information on the possibility of building a modified heat pipe. So this is in the early stage.
If you used a different working liquid, one with a lower heat of vaporization, this would offer more cooling, but since it would evaporate quicker, you would have to use more volume of that liquid than the water. My question is, how would that greater volume affect the pressure? It seems like it would make the pressure greater. Therefore, would using a non-water working liquid in a passive heat pipe be an improvement? Would this change in liquid necessitate a greater vacuum inside?
Appreciate any help you guys can offer. Thanks
