- Mar 28, 2003
Well, the connector on my side panel is going to change from the ATX connector I used in this thread:
http://www.ocforums.com/showthread.php?t=457990
I just got the cable from dad, which has the connectors needed for a LEMO coupler I've had lying around.. Here's some pix.
Here's the coupler. It's a surface mount component, which has a push pull disconnect connection from the back, and then another one at the front:
This is the connector for the front, which has one key:
And this is the connector for the back, which has two keys:
These are those expensive LEMO connectors. Water tight seal around the back of the connector around the cable, clean room certified, precision machined chrome plated brass body, nickel plated brass latch, sleeve and mid pieces.
Can't wait to get this baby installed. ^_^
......Someone get Captain Slug a bucket....too much drool!!!!!!!
