Hi everyone,
I have a pretty extensive cooling setup for just a Ryzen 1700 @ <4.0GHz (lost the lottery hard), and a GTX1080 Ti.
The GPU is fine in idle (32c) and load (~55), 120% pl and tight OC. The CPU on the other hand idles after a while around 45c, and with just 3.80GHz at 1.4V it runs up to 75-80c. I'm honestly thinking I forgot to put the TIM inbetween, after just test-installing it months ago (it was a long project). I mean, surprisingly it's not overheating when this is the case, but on the other hand the cooling should be quite fine for even the CPU + 2x GPU. I've barely seen the water hit 40c after extensive runs, so the pump is doing fine at 100%.
Can I reasonably expect the CPU to idle around the same temperature as the GPU, slightly above water temp? Even in fixed 3.8GHz OC idle (so no P-states, this mobo doesn't allow)?
Setup:
GA-X370 Gaming 5 + EK monoblock
2x EK-CoolStream SE 360 + 2x 3x Noiseblocker fans
EK-XRES DDC 3.2.
One thing I worry about as well is the air still present in the top of the two compartments of the monoblock, roughly around top VRM's area. I haven't fully flipped the system over yet, but I don't think it's the cause of the high CPU temperature either.
Maybe some of you can shed some light on this, what else could possibly be wrong, but I can simply only think of forgetting the bloody TIM, which I can check maybe tomorrow.
Regards,
Al
PS: Galaxy S5 picture quality, but eh:
Setup:
EK-XRES DDC 3.2.
Regards,
Al
