SETUP:
Gainward GeForce GTX 260 896MB PhysX
PCI-Express 2.0, "Golden Sample", 2xDVI, HDCP, Cor
Microsoft Windows Vista Prem Engelsk
SP1,OEM,DVD,64
Corsair Dominator TWIN2X PC8500 4GB DDR2
Kit w/2x 2GB XMS2-8500 dimm's, CL5-5-5-15, 1066MHz
AMD Phenom II X4 940 Black Edition
125W, AM2+, 8MB Cache, 3,0Ghz, Boxed
Corsair 850Tx psu
CoolerMaster dominator 690 chasis
Hello...My motherboard was faulty (ASUS M3N-HD/HDMI)...I must get a new one from supplier but they no longer carry the one I had. Which of these is best? ( will be running one GTX260 but later will invest in a second GTX260 and run in SLI.)
which of these are a better choice ...will O/C in the future but not to begin with (first build...need to learn first)
http://www.newegg.com/Product/Produc...82E16813131383
Asus M4N82 Deluxe
OR
http://www.newegg.com/Product/Produc...82E16813131367
Asus M4N72-E
Don't consider price as these will be bought fromm swedich site...prices are 1169 and 1145 sKr respectively...Just wondered waht the advantages were with the 980a chipset..will not be running 3 cards.. The ASUS website though doesn't list the Asus M4N82 Deluxe as running Corsair TWIN2X4096-8500C5D Ram in QUOTE"Supports one pair of modules inserted into either the blue slots or the black slots as one pair of DUAL-CHANNEL memory configuration" UNQUOTE .......I read this as it will NOT run two paired stick totalling 4096 at 1066mhz?
ALso any advice on a CPU cooler/fan for AMD PII X4 940 black CPU over the stock cooler fan (what is the stock cooler on these?)....please include details if your choice would need additional brackets or anything ?
Thanks for the help in advance
SP1,OEM,DVD,64
Corsair 850Tx psu
Asus M4N82 Deluxe
OR
Asus M4N72-E
