S Shepard Registered Joined Jan 16, 2012 Jan 26, 2012 #1 Hi im planning to buy a new motherboard, my budget is around $160. Ill overclock. Im choosing between asrock 990fx extreme3/4 MSI 890GXM-G65 Asus M5A88-V EVO or you can suggest other boards. thanks
RGone Senior DFI Staff Joined Apr 20, 2004 Location JAX, Mississauna Jan 26, 2012 #2 From a list of motherboards used in overclockinig 1055T. These were used far more than any other model of motherboard as reported. These three boards will clock that cpu to 4.0Ghz if the cpu is good and the ram is DDR1600 with good cooling. Asus m4a89gtd pro/usb GA-890GPA-UD3H Asus Crosshair IV 4.0Ghz takes 1.45 to 1.5Vcore 14x286 = 4004Mhz 4.0Ghz takes 2.6 to 2.8Mhz NBCPU and 1.30 to 1.35 NBCPU voltage. Like I said most of those boards showed the ram at DDR1600.
