My current motherboard is an ASUS M2MPV-MX running Win7 64bit Home with 4GB RAM and AMD Athlon 64 x2 Dual core 5200 MHz on a BIOS RAID 0 (Stripe) array with 2 identical 250GB dives. This setup has been working without any problem since installing Win7 over a year ago. I have a basic cable Home LAN linking another Win7 Laptop and a separate Linux desktop - all working OK.
I need to setup another desktop using a WiFi connection as I cannot run a cable to its position. I have an old desktop running WinXP which is working OK on the WiFi, but it is very slow indeed.
I would like to upgrade my main desktop listed above. The cheapest solution is to purchase a new motherboard, CPU and memory, and install these in my desktop - swopping out the M2MPV board, CPU and RAM, to install these in the 'old' desktop in its new position, with a fresh install of Win7 on this.
However, I suspect that fitting a new MB, CPU, and RAM in my original desktop, while being quite straightforward in itself, - I will discover that on first booting up, and creating a RAID 0 setup in the BIOS, I will have 'lost' my RAID array along with my data!
So, my questions are, how best to achieve no loss of data? Is there a way to create a RAID 0 array without wiping out all the data on the hard disks? Or, is there a fool-proof way of backing up my existing system - full backup of OS and data, - say a full 'image' backup, which can be 'restored' to the drives after creating the array on initial backup? Any/all advice gratefully received.
