- Jul 30, 2011
- NYC & FL
With the system Setup i have listed below...
1. What would be the most efficient & or most optimal tweak or Stable OC i can set on my MSI 880GM-E43 (MS-7596 v1.3)?
2. What is the setting i should use for my CPU & RAM within bios version (AMI 7596v2B)
Any help, suggestions would greatly be appreciated.
I do a lot of Photoshop, Illustrator, Microsoft Expression Web (for web page coding), AutoDesk AutoCAD & Revit Architecture 2010. So my system would need to be able to kick a$$. I sometimes run these programs at the same time and get lag and or BSOD. I just want to tweak it, forget it and not have to worry about it ever.
Please Help, Thanks
__________________________________________________
MoBo: MSI 880GM-E43 (MS-7596 v1.3) Bios: AMI 7596v2B
CPU: AMD Phenom II x6 1055T (Thuban) - 2.8GHz, 3.3Ghz Turbo Core
RAM: G.Skill F3-12800CL9-2GBNQ (9,9,9,24,1T)
Video: HIS HD 5670 IceQ 1GB (128bit) GDDR5 PCIe v2.0 x16
HDD: (C:\) WD 500GB Sata & (D:\) WD 1TB Sata
ATAPI: HL-DT-ST DVDRAM GH24NS50 & SONY DVD RW DRU-540A
Sound: Onboard - ATI SB600 - High Definition Audio Controller
NIC: Onborad - Realtek 10/100/1000 Ethernet NIC
PSU: Extreme mn: RSY-645 450W P4 ATX 24PIN
Case: Novatech Galaxy III
OS: Windows XP SP3 x32bit
Please Help, Thanks
