Hi,
I formerly had an Asus P8P67 with a 2600k, but they both broke while in warranty.
As part of the warranty settlement I got a MSI Z77A-GD65, and a new 2600k.
My cooler is the Scythe Mugen 2.
I installed them yesterday and tried an OC, but I get strange symptoms.
With the multiplier set to anything above 36 (now 43), the clock speed just jumps around.
Whether EIST is enabled or disabled, when I start Prime95 or LinX, for 2-3 seconds it jumps to 4.3Ghz, and then jumps between 3.8-3.9-3.7Ghz.
I tested with all power saving features off, to no avail.
All voltages are set to automatic.
Temperatures are normal. After several hours at 3.8Ghz on LinX, it doesn't go over 72°C.
Is it 3.8 the max of this particular cpu, or am I overlooking something?
