Happy Saturday folks!
Running a maximus v extreme with a 2700k and can get to 5500 (55x100) just by raising core voltage to ~1.58v but so far am unable to get 1 drop more. Adding bclk up to ~105 gets me to the windows splash but the system locks up immediately following the kbd/mouse power cycle. A cpu multi of 56x does the same thing as does raising bclk to 101. Have tried adding more core voltage (tried up to 1.75v) but nothing. Tried raising vccio to 1.15, nada.
When I ran with a multi of something like 32x I was able to get 107bclk but no further. If I set the cpu multi to anything over ~40x when bclk is over 102, the system hangs just after the windows splash kbd/mouse power cycle again.
Most settings are pretty much left alone...everything useless for me is disabled. All the eist and c-state stuff are enabled. Set ram timings manually, tridentx 2666 at stock atm (11-13-13-35-2).
It's solid as a rock at 5500...passes as many runs of linx and p95 as I let them run. Temp never gets higher than 6C. Figure there should be more MHz available here.
Ideas?
TIA as always!!
Ideas?
TIA as always!!
