- Dec 13, 2002
- Ohio
Really to be honest with watercooling usually one of the main benefits becides the occational higher oc is the lesser amount of noise. With a chevette heatercore and a pair of 120mm fans you can make a fairly efficient and quiet setup. Only complaint I had about my WC experience was the fact that my tygon was so hard to get into the right positions it ended up forcing me to stick the pump right next to the case door and every once in a while it would push the pump into the door causing the case to chatter(very annoying). I think the key to a quiet setup is large fans and proper mounting of the pump lol. Also if you want an easy setup I always say use a rez since I tried the t-line thing and it is a real pain to fill and bleed. Cheap rez equals pvc pipe and some fittings at the local hardware.
