- Jun 25, 2008
First off... Thank you all for helping me get this far. I could not (absolutely not) done it with out the help you have provided. Thank you.
After hours (and hours, and hours) of hair pulling and system failures, I believe I have a stable overclock on my i7 930 but I could only pull off 3.67 GHz (kind of wimpy I know!). AT THIS POINT, I WELCOME CRITISM AND COMMENTS !
My case is nothing special and only includes two 200mm fans (one to push and one to pull).
Bottom line ------> Its QUIET, Its Stable, Idle temp is 42 deg, Load temp is 75 deg. (keep in mind though that ambient in this room is 24.5 degrees which is a bit warmer than typical) I am not sure if 75 deg on push air only is acceptable for 3.67 GHz. Any further tinkering will surely push me into the 80's.
Unfortunately, I think I am stuck with a chip from the bad batch as it is impossible for me to break the 176 MHz BCLK barrier without exceeding a forbidden VTT of 1.35V. I elected to back off to 175 MHz just to provide a slight buffer as 176 was barely stable.
In this difficult process, there are a few things I have concluded:
i) I believe my chip is one out of the much talked about "bad batch" as a QPI/VTT of 1.335V is the absolute minimum I can go to get 175 MHz.
ii) This o/c was achievable without LoadLine calibration but it required a VCORE of around 1.34 volts. I finalized by using Level 1 (slight adjust for vDroop) because it allowed for a lower VCORE of 1.25V which results in a lower idle temperature while hitting the same load temps. Since my PC spends more time in idle then load, I figured this was more important.
iii) I don't think LoadLine Cal has any effect on the QPI/VTT as far as I can tell from testing so I still needed 1.335 V even with LLcal enabled.
iv) Turbo mode causes more headaches than its worth so avoid it if you can.
My build:
i7 930 with Venomous X Cooler (120mm PUSH only)
Gigabyte X58A-UD3R (Bios Ver. FD)
Mushkin Enhanced Blackline 3x2GB DDR3 1600 (7-9-7-24)
HAF 912 case (one front 200mm push fan, one top 200mm pull fan, and one 120mm rear pull).
Corsair 650TX
Still rockin' the classic XP Pro.
Well, go ahead and beat the hell out of my work and let me know your thoughts. Thanks.
My build:
Corsair 650TX
Code:
[COLOR="Red"]My bios settings:
Advanced CPU Features {Press Enter]
CPU Clock Ratio............................: 21x
CPU Frequency .....(Ghz)...................: 3.67
Intel(R) Turbo Boost Tech..................: DISABLED
CPU Cores Enabled..........................: ALL
CPU Multi Threading........................: ENABLED
CPU Enhanced Halt (C1E)....................: DISABLED
C3/C6/C7 State Support.....................: DISABLED
CPU Thermal Monitor........................: DISABLED
CPU EIST Function..........................: DISABLED
Bi-Directional PROCHOT.....................: AUTO
Virtualization Technology..................: DISABLED
Advanced Voltage Control [Press Enter]
>>>>CPU Voltages
LoadLine Calibration.........................: STANDARD
CPU Vcore....................................: 1.250
QPI/VTT Voltage..............................: 1.335
CPU PLL......................................: 1.80
>>>>>MCH/ICH Voltrage
PCIE.........................................: 1.5
QPI PLL......................................: 1.2
IOH Core.....................................: AUTO
ICH I/O......................................: AUTO
ICH Core.....................................: AUTO
>>>>>Dram
DRAM Voltage.................................: 1.66
DRAM Termination.............................: AUTO
Ch-A Data Vref...............................: AUTO
Ch-B Data Vref...............................: AUTO
Ch-C Data VRef...............................: AUTO
Ch-A Address Vref............................: AUTO
Ch-B Address Vref............................: AUTO
Ch-C Address VRef............................: AUTO
Uncore & QPI Features [Press Enter]
QPI Clock Ratio*...........................: AUTO
QPI Link Speed* ......................(Ghz): 6.3
Uncore Clock Ratio.........................: AUTO
Uncore Frequency......................(Mhz): 3500
Isochronous Support........................: ENABLED
Advanced Clock Control [Press Enter]
>>>>>Standard Clock Control
Base Clock (BCLK) Control*.................: ENABLED
BCLK Frequency (Mhz)*......................: 175
PCI Exxpress Frequency (Mhz)...............: 100
CPU Clock Drive (mV).......................: 800
PCI Express Clock Drive (mV)..............: 900
CPU Clock Skew (ps)........................: 0
IOH Clock Skew (ps)........................: 0
Advanced Dram Features [Press Enter}
Performance Enhance........................: EXPERT
Extreme Memory Profile (X.M.P.)............: DISABLED
System Memory Multiplier (SPD).............: 8x
Memory Frequency (Mhz).....................: 1400
DRAM Timing Selectable (sPD) ..............: AUTO
Channel Interleaving............................: AUTO(6)
Rank Interleaving................................: AUTO(4)
Channel A Timing Settings Sub Menu [Press Enter]
>>>>>Channel A Standard Timing Control
Cas Latency Time.............................: 7
tRCD.........................................: 9
tRP..........................................: 7
tRAS.........................................: 24
>>>>>Channel A Advanced Timing Control
tRC..........................................: AUTO
tRRD ........................................: AUTO
tWTR ........................................: AUTO
tWR..........................................: AUTO
tWTP.........................................: AUTO
tWL..........................................: AUTO
tRFC.........................................: AUTO
tRTP.........................................: AUTO
tFAW.........................................: AUTO
Command Rate (CMD) .....................: AUTO
>>>>>Channel A Misc Timing Control
B2B CAS Delay................................: AUTO
Round Trip Latency...........................: AUTO
Channel A Turnaround Setting [Press Enter]
>>>>> Channel A Reads Followed By Reads
Different DIMMs..............................: AUTO
Different Ranks..............................: AUTO
On The Same Rank.............................: AUTO
>>>>> Channel A Writes Followed By Writes
Channel B Timing Settings Sub Menu [Press Enter]
>>>>>Channel B Standard Timing Control
>>>>>Channel B Advanced Timing Control
Command Rate (CMD) ..........................: AUTO
>>>>>Channel B Misc Timing Control
Channel B Turnaround Setting [Press Enter]
>>>>> Channel B Reads Followed By Reads
>>>>> Channel B Writes Followed By Writes
Channel C Timing Settings Sub Menu [Press Enter]
>>>>>Channel C Standard Timing Control
>>>>>Channel C Advanced Timing Control
>>>>>Channel C Misc Timing Control
>>>>> Channel C Reads Followed By Reads
>>>>> Channel C Writes Followed By Writes
[/COLOR]
