SewerBeing said:Travis I do not think this point applies too much here lets for the moment assume its a linear relationship between the strength of the pump and the length of that accelerating piece (which it probably is not its probably quadratic. So a 1hp pump needs 12" and our D5 pumps are .032hp at peak consumption. So that pump is 31.25 times stronger than our pumps. So assuming its a linear relationship it would be .384" for us. However more data would be needed and I have no faith in these numbers, if you could provide us a little bit more data I would probably be able to build us a fairly accurate model of what we need. If you could tell us what you would use for say two different pump sizes we would have a much better idea of what we need. Also you are using 1.5" while we use .5" which would have an effect on the path also. So if anyone wants to do more testing I would be happy to digest the data.
I will dig up some technical data for you on reccomended velocitys on Monday.
