Are you buying this all right now?
No I can buy when they are on sale, but would like everything by early April, Late April at latest (i check SD! all the time and newegg, etc)
When do you get your check?
I dunno when they send them, i'm not really dependent on it for when I make my purchases (I have enough to cover it w/out check but i will put that money "towards" upgrade and I thought the title was catch)
The reason I ask is the Antec 900 is too expensive @ $120, you can often get it or a P180 for $60 AR.
Yes I saw this expired on SD! and it seems there have been quite a few deals as of late
You could also wait for the CM690 which is often $20 AR.
Do you like this one better then antec 900?
The Corsair PSU often has rebates as well. This could save you over $100.
thanks for heads up!
I would go for 4GB of ram, 2x2GB. I really see no reason not to, it isn't that much more expensive and again you can wait for a rebate deal. With 4GB you will need to run a 64bit OS.
Yeah I have XP home though and wasn't planning on getting vista (yet)
The G9 is crazy expensive, if you like your 510 I would stick with it. I went from a 510 to a G5 and really there isn't any noticeable difference to me. It may just be the cheapness in me, but there is no way I would pay over $30 for a mouse, I picked up my G5 for $25 a few years ago.
you seen the g5 v2? or have it? might get that instead (I will see how mx510 does when new system is up
I would also hold off on the sound card, try out the onboard. If you think its good there is no point in spending the extra money. Only reason I have an X-Fi is because I won it at a Counter-Strike tourny. I plan on trying out my new MB's onboard and maybe selling the X-Fi since their Vista drivers are horrible, 20% CPU usage unless I disable all of the enhancements.
Does x-fi go on sale often? If you are CS player don't you notice difference with audio card as opposed to on board? or not really?
Definitely get a nice heatsink and overclock the CPU.
Thermalight ultima-90 and a 120mm fan sounds good for this
If you can't tell I am cheap lol. I am happy with a good system at a lower cost, but there is nothing wrong with paying the extra to get the best. Just depends on what you want and what you are willing to pay.
