- May 15, 2010
- Euroland, Denmark
I have just finished cleaning my newly bought second hand EK LTX water block.
I thought i would share my process with you guys.
Items you will need.
Small container
Vinegar
Old toothbrush (or new if you want to use that)
First off, take apart the water block.
You can see the block is pretty dirty and will cause performance loss and flow restriction in your loop. The dirt is hard, and stuck into the ripples of the block.
Ready to get to work.
The copper part of the block submerged in vinegar. The vinegar will soften up and loosen the dirt.
I left the block in the vinegar for about 20 to 25 minute and then got out the tooth brush so that i could really get into the ripples in the block. You can already see the dirt has started to disappear on its own.
After this, i ran the block under a tap and dried it off.
Sparkling clean!
As a small bonus, the face of the block is also fully clean now, the vinegar takes almost everything, also left over thermal paste.
I hope someone can find this guide useful
Small container
Vinegar
Sparkling clean!
