Corzahazard
- Apr 25, 2016
Well, my current PC is becoming doorstop material and I'm well overdue for a new build.
I would appreciate some input from you guys as to whether I am on the right track, basically I'm looking at a rig that will play whatever I want whenever I want.
CPU - FX-8350
MOBO - Sabertooth 990FX R.2
Cooler - Coolermaster V8 GTS
GPU - Radeon R9 380
PSU - EVGA SuperNOVA 650W 80+ Gold (full modular)
RAM - G.Skill RipjawsX DDR3 1866 16GB (2x8gb)
HDD - 2x Seagate 4TB SSHD
DVD or Bluray burner
extra case fans
Case - Corsair Graphite 780T
I want to overclock this cpu to as close to 5Ghz as possible too, the reason behind the V8 GTS cooler was that it looks freakin' awesome and is a triple tower and by the looks of it would give a lot more clearance with the ram, and while I know Noctua is the better option, I would like something that doesn't look like so much of an eyesore.
On the topic of ram, is it better to run 2x8GB sticks or run 4x4GB sticks?
I've heard the Sabertooth board is one of the better boards to overclock the 8350 next to the Formula V (a bit pricey for me) but will the other 990FX boards give me the same OC for a cheaper price? I was looking at either the Gigabyte GA-990FX-GAMING or the Gigabyte GA-990FXA-UD3 R5, both being a bit cheaper but I wasn't sure if they'd achieve the same clocking ability.
I'd also like some input as to the GPU too, eventually I would like to run 2 in crossfire but I'm up in arms as to whether it's worth doing it that way, and there are so many choices I guess I'm a little overwhelmed as to which one to choose (been a while since my last build which turns out I made a lot of mistakes when choosing parts and don't want to find I'm wasting my $$$ again)
I figure a 650W PSU should run this system for now but will more than likely need to beef it up if I introduce a second GPU in the future.
As for the case, it looks pretty damn sweet and looks like it has a lot of breathing room for future upgrades, not sure how well air cooling will go with this cpu with high OC's, so figure a case with room for a cooling loop won't hurt, plus I really like the way corsair has designed this case with the SSD bays tucked away, so if SSD's become affordable I can install those and tuck them away for a much cleaner look and give more airflow through the case without having drive bay racks in the way of the front fans.
I would also like to know if the Seagate SSHD's are worth it? or if I'd just be better off going for the Barracuda's instead.
Honestly I would love as much help as I can with this build as I would like this build to be done properly this time.
I am also a 'fanboy' (and yes I hate that term haha) of AMD, so please don't suggest Intel. Basically all of my mates that got me into PC's/modding/overclocking/etc. all had AMD based systems and it kinda just grew on me.
Thank you in advance and look forward to your input, suggestions and criticisms
Also, sorry for all the questions, just making sure I'm on a path to glory
Peace
Corz
CPU - FX-8350
GPU - Radeon R9 380
extra case fans
Peace
Corz
