- Jun 29, 2013
- Houston, Texas
Ok first off, my pc ain't too shabby right now - see sig. When I started construction on this thing back in March I envisioned a machine to absolutely max graphics in ALL games I currently play. I also wanted to machine to do transcoding, Cad modeling, video editing and some 3d rendering (I am currently exploring 3d rendering but not much experience) Also for the machine I want a high end liquid cooling system, good airflow, good hard drive space, very good overclocking for benching and near silence! I currently plan on recycling parts from my current pc into a transcode server that I will have running in my closet so transcoding no longer needs to be built into the main machine.
I have been on newegg and frozencpu for months now planning my new build. What I am sure of is I want a 6 core intel so that narrows down my socket to 2011. The ram I already have (see sig) I am dead set on a 900D for my case. I know this is not required but I like knowing exactly what is going on with my pc at all times at a quick glance. I am eyeballing a couple of ultra wide LG 29's in portrait mode (1 off to each side) for monitoring software such as flow pressure, flow rates, temps, fan control, yadda yadda yadda. In the center I am looking at 4 Asus 144hz 24" monitors for surround and recycling the rest of my 3 24" asus 60hz for extended displays. That gives me a total of 8 monitors.
Here is what I have to work with. I can spend roughly $1500 - 2000 a month on this build. I plan on building a little each month until this pc is fully operational. Cost limit? I'd like to keep it under 7k. Cheaper is preferable but not required.
These are the parts I currently own and are not required for the new build.
EVGA GTX 780SC Edition.
G.Skill Trident X 32GB (F3-2400C10Q-32GTX)
*3 ASUS VS248H-P
OCZ Vertex 4 VTX4-25SAT3-256G 2.5" 256GB SATA III MLC
This is what I would like from the community. This is an open ended build. I want to start up a serious debate pertaining to my particular needs, wants and dreams right here in this thread. As the build progresses I will do another thread for a build log as in depth as I can be. Winter time is here boys! For a land surveyor that means a lot less time out in the field and more time in the garage making toys!
Gentlemen - Have fun!
Build Parts List
Case | Corsair Obsidian Series 900D CC-9011022-WW Black Aluminum ATX Super Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139019
Motherboard | ASUS Rampage IV Black Edition LGA 2011 SATA 6Gb/s USB 3.0 Extended ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813188131
OR
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132053
CPU | Intel Core i7-4930K Ivy Bridge-E 3.4GHz LGA 2011 130W Six-Core Desktop Processor BX80633i74930K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116939
Memory (purchased)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231590
SSD ( 1 Purchased, 1 more needed ) | OCZ Vertex 4 VTX4-25SAT3-256G 2.5" 256GB SATA III MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227792
PSU | CORSAIR AXi series AX1200i 1200W Digital ATX12V v2.31 and EPS 2.92 SLI Ready CrossFire Ready 80 PLUS PLATINUM Certified Full Modular Active PFC Power Supply New 4th Gen CPU Certified Haswell Ready | $339.99 +shp
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139039
GPU (1 owned, 1 or 2 more needed) |
EVGA ACX Cooler 03G-P4-2784-KR GeForce GTX 780 3GB 384-bit GDDR5 PCI Express 3.0 SLI Support Video Card | 1st $725.26 @ Fry's
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130918
Cooling System
*3 ASUS VS248H-P
Build Parts List
OR
Memory (purchased)
Cooling System
