- Jun 12, 2010
- Dallas Tx
Okay so finally, after 2 months of extensive, in depth research, I have finally made my decision and made all the purchases (close to 3500 dollars) I plan on doing some serious gaming on this rig (crysis, call of duty 4, bad company, etc..) I also plan on overclocking the cpu close to4ghz. Does anyone have a similar rig setup and do you think my cooling system is adequate enough for my rig?
Hardware:
Intel Core I7 930
Asus Rampage III Extreme
Corsair Dominator Triple Channel DDR3 1866
1x Radeon HD 5970 Sapphire
Corsair 850w power supply
WD VelociRaptor 300GB Hard drive
Windows 7 Ultimate
Case and cooling system is complete from Danger Den.
Case-DD tower 26 uv blue
Radiator- RAD-3440 Black Ice GTX480
Pump-PUM-L200 DD12V-D5 Pump Variable Speed by Laing
GPU block-GPU-6899 DD-5970 Water Block
CPU block-1 CPU-510 MC-TDX for Intel I7/Nehalem/1366
Fans- 6 FAN-YL3 Yate Loon 120mm High Speed Fan: D12SH-12 (4 on the radiator, 2 on the rear exhaust, im thinking that setup might give the case a slight amount of positive pressure)
Tubing-TUB-5105 Tygon 3603 Tubing 1/2 in
Coolant-FLU-R300 MCT-40 Non-Conductive Solution
I think overall i made pretty good desicions, although this is my first watercooling build. Im still waiting for all the items to ship here. Anyone have a rig similar to this? I welcome any suggestions/comments on what i could do to improve anything. Thank You, Jerrod
Hardware:
Intel Core I7 930
Windows 7 Ultimate
