Whatup everyone!
I haven't been on this forum a lot, but having researched a ton of hardware, and having been lead to this place several times by almighty google I figured I'd better go things are taking place these days.
Anyway I'll be building my next gaming rig in about a weeks time (My current build is a good 4 years old, sports a stable 3.6 GHz Q6600 stable OC and is still going strong, but given my work requires gaming, recording, and rendering, its just not up to peer anymore). Naturally I'm researching parts and making sure I'll be getting something that will hopefully last as long as this build has, and also have head run for some decent OC'ing (no crazy **** though).
I'll be making a very detailed list below, and I'd like your opinion on why these are good/bad choices, and any recommendation for changes, as long as you keep my needs in mind. Also keep in mind that the prices of the items are not going to be the same for as it is for you, as I'll be using stores in my country (Denmark), and some brand pricing are not necessarily the same as in the US.
EDIT: Parts are all ordered
This build is made to allow for these future upgrades:
Single Card => 2 way SLI
16 GB RAM => 32 GB RAM
Current Pieces:
CPU: Intel i7 3770K http://www.newegg.com/Product/Product.aspx?Item=N82E16819116501
Thought Note: Need as much CPU power as possible for rendering speeds
CPU Cooler: Noctua NH-D14 http://www.newegg.com/Product/Product.aspx?Item=N82E16835608018&Tpk=Noctua DH 14
Thought Note:
Mobo: MSI Z77A-GD65 http://www.newegg.com/Product/Product.aspx?Item=N82E16813130643
Thought Note:
RAM: Corsair Vengeance 2 x 8 GB http://www.newegg.com/Product/Product.aspx?Item=N82E16820233280
Thought Note: Vengeance is just a no brainer. It gives me the 2 x 8 I want for a low price. Only conflict is whether to go Low Profile or Regular.
GPU: MSI Gigabyte GV N670OC http://www.newegg.com/Product/Product.aspx?Item=N82E16814125423
Thought Note: Great performance, great reliability, great price. Still thinking about going all out on a GTX 680 http://www.newegg.com/Product/Product.aspx?Item=N82E16814125422 but don't know if I want to pay the extra bucks.
PSU: CORSAIR HX Series TX850 V2 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139022
Thought Note:
Case: Cooler Master HAF XM Midi Tower http://www.newegg.com/Product/Product.aspx?Item=N82E16811119257
Thought Note: Great case, great price. Playing with the thought its bigger brother the HAF X Full Tower, but honestly I see why I'd need it.
HDD: Western Digital WD VelociRaptor WD6000HLHX 600GB http://www.newegg.com/Product/Product.aspx?Item=N82E16822136555
Thought Note: Salvage from my current rig. About 1 year old. Great Recording Drive
HDD: Western Digital WD Black WD1002FAEX 1TB http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
Thought Note: Need the extra space for damn sure, and I always had good experience with WD Hard Drives. Great Price aswell.
SSD: Corsair Neutron Series 120GB http://www.newegg.com/Product/Product.aspx?Item=N82E16820233340
Total Price: $1507 (Calculated from the shops I'll be using in my country. VAT removed)
Additionals I'd like to make, but find hard to justify:
Thought Note: I'd really like this as an OS drive, and while price isn't the most important to me, I simply can't afford both this and the WD Black, and from what I understand this is the situation if I go with the SSD:
Pros:
Much faster speeds
Cons:
Shorter life span
Less reliable (more prone to errors)
Much less space
Now the way I see it, the speed doesn't make up for this, considering that its only load times we are talking about. If I could use it as a recording drive, that might justify it, but I have been told that SSDs aren't noticeable better when it comes to writing continuously, large files.
If someone can shed some light on this situation, if I'm completely wrong, please do this.
EDIT: Build Change List:
Changes: Alternative PSU change from 750W to 850W of the same model. Considering its a Bronze Certified PSU, I thought it'd be better to be on the safe side. That said I'm still keeping the HX750 as my primary choice for now.
Changes: Primary choice for GPU changed from MSI N660 Ti PE 2GD5/OC to GIGABYTE GV-N670OC 2GB
Changes: SSD added to build
Changes: ASRock Z77 Extreme4 switched for MSI Z77A-GD65 - A bit unnecessary, but the extra cash doesn't make much difference to me.
Changes: Zalman CNPS9900 MAX switch with Noctua NH-D14 - The lower noise and lower temps its gonna provide over the CNPS9900, coupled with a down haggled price with the store made it worth it.
Current Pieces:
Thought Note:
Thought Note:
Thought Note:
Pros:
Much faster speeds
Cons:
Shorter life span
Much less space
