nice. I think I'm going to copy that design when I work on upgrading this one. Should be much less restrictive and cool as wellReflex said:I did something similar but i used compression fittings as i found it easier:
That looks great hows the temps/flow on that system and where did you get the fittings
Sorry I can't be more accurate about this... My goal was silence rather than excellent temperatures so I really don't have an accurate idea of what my loop is capable of. My temps are the same now (heatercore + pipe) with no fans running as they were with just the heatercore and my 120x38mm, 124CFM Y.S. Tech fan running at ~9volts. That is my motherboard reports that I'm running at 51c load in a room that's ~70f; that jumps to about 60c at a room temp around 80f. Please bear in mind that my mobo seems to report temperatures about 10c too high. Also interesting to note is that the temperature also fluctates far less between idle and load temps after the addition of the pipe, but I don't why this would be.n6b72g said:I am contemplating making a radiator like this, i was just at home depot tonight looking at supplies. Can you give an idea of what your temps were before you added this radiator, and then what they were after?
Fins would work MUCH bettern6b72g said:Does anyone think increasing the tubing to 3/4" would yeild much better results in temps?
were did u get the hardwareReflex said:I did something similar but i used compression fittings as i found it easier:
