Since your setup was the same except thermal compound and coolant mixture and you cannot achieve the same results then it's most likely due to the mount or a bad mixture (which probably isn't the culprit?). Lapping might help but I don't think the base is the problem. Did you use the same springs also? Since nothing changed and it worked before than it should work again is what I'm saying.
