- Feb 21, 2004
- stillwater, mn
also like i said check the nozzle, and put in #4.
thegame said:also like i said check the nozzle, and put in #4.
netboy said:on a DD rbx wb there are 5 differnt nizzles, 1 is default 2-4 vary in sizes, 4 being the biggest and five supposed to be the best, it has a bunch of little holes instead of one big one. This is supposed to eliminate any hot spots. But the problem is that the holes are so small that they often get clogged with acylic flakes for the res or junk from the tubes, bacteria growth ect ect.
Gulinborsti said:IMHO 50°C at load is ok for a CPU running at 25000MHz and it's also not too high for running at 2500MHz.
And how far do you expect the temps to drop by removing the GPU block? I guess you will be dissapointed when you try it, <3-5°C (guessed).
try another rad or fan setup first...
fafnir said:its the 25000mhz part
netboy said:
