CircuitBreaker8
Disabled
- May 4, 2004
- Silver Spring, MD
veryhumid said:that's a great clock! What kind of numbers could you get on the stock vga silencer?
bobmanfoo said:good idea, i never liked the way the fans are setup on gpu coolers. having the fans flat and close to the HS surface, then making the air turn 90 dergrees with no curvature is soo inefficient and causes great amounts of turbulence, and on top of that it has to flow through a set of long fins
some of thoughts if i may:
you should use a smaller fan, or better yet put a shroud on it.... ur leaving the 'good parts' of the fan, airflow, unused. and maybe incorperating the plastic housing of the silencer to exhuast the hot air through the pci slot to lower case temps? it is one of the great features of silencer
CircuitBreaker8 said:Can you post a pic Cerberus2k7?
username17 said:where did you get that heatsink?
I'm looking at the zalman, but I think it's too big.
I already have a 80mm on the stock hs...
-username17
